Ga door naar hoofdinhoud
Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement
Wat je nodig hebt
  1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: stap 1, afbeelding 1 van 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: stap 1, afbeelding 2 van 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: stap 3, afbeelding 1 van 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: stap 3, afbeelding 2 van 2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: stap 4, afbeelding 1 van 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery.
  6. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: stap 6, afbeelding 1 van 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: stap 6, afbeelding 2 van 2
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: stap 7, afbeelding 1 van 3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: stap 7, afbeelding 2 van 3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: stap 7, afbeelding 3 van 3
    Koop
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
Conclusie
Jessica Beckford
527 Reputatie
4 handleidingen geschreven
USF Tampa, Team S15-G4, Boczar Spring 2018 Lid van USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 188
