Ga door naar hoofdinhoud
Acer Aspire a515-46 SSD Replacement
Wat je nodig hebt
  1. Acer Aspire a515-46 SSD Replacement, Turn off: stap 1, afbeelding 1 van 1
    • If laptop is not already off, hold power button for 5 seconds until screen shuts off.
    • If needed, backup any files to a USB or an external hard drive before turning off and replacing SSD.
  2. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 1 of 3: stap 2, afbeelding 1 van 1
    • Flip the laptop over and locate the screws on the back panel.
  3. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 2 of 3: stap 3, afbeelding 1 van 3 Acer Aspire a515-46 SSD Replacement, Remove Back Panel 2 of 3: stap 3, afbeelding 2 van 3 Acer Aspire a515-46 SSD Replacement, Remove Back Panel 2 of 3: stap 3, afbeelding 3 van 3
    • Using a Philips head screwdriver, remove all of the screws on the back panel.
  4. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 3 of 3: stap 4, afbeelding 1 van 3 Acer Aspire a515-46 SSD Replacement, Remove Back Panel 3 of 3: stap 4, afbeelding 2 van 3 Acer Aspire a515-46 SSD Replacement, Remove Back Panel 3 of 3: stap 4, afbeelding 3 van 3
    • Use a small screwdriver or prybar to pry the back panel away from the laptop.
  5. Acer Aspire a515-46 SSD Replacement, Remove Battery 1 of 3: stap 5, afbeelding 1 van 2 Acer Aspire a515-46 SSD Replacement, Remove Battery 1 of 3: stap 5, afbeelding 2 van 2
    • Remove the two pieces of tape holding the battery connector and wires.
  6. Acer Aspire a515-46 SSD Replacement, Remove Battery 2 of 3: stap 6, afbeelding 1 van 3 Acer Aspire a515-46 SSD Replacement, Remove Battery 2 of 3: stap 6, afbeelding 2 van 3 Acer Aspire a515-46 SSD Replacement, Remove Battery 2 of 3: stap 6, afbeelding 3 van 3
    • Using your fingernails, pinch the battery connector on both sides and pull it straight back until it is removed from the socket.
  7. Acer Aspire a515-46 SSD Replacement, Remove Battery 3 of 3: stap 7, afbeelding 1 van 2 Acer Aspire a515-46 SSD Replacement, Remove Battery 3 of 3: stap 7, afbeelding 2 van 2
    • Pull up and remove the battery from the compartment.
  8. Acer Aspire a515-46 SSD Replacement, Replace SSD 1 of 3: stap 8, afbeelding 1 van 2 Acer Aspire a515-46 SSD Replacement, Replace SSD 1 of 3: stap 8, afbeelding 2 van 2
    • Use a small Philips head screwdriver to remove the screw holding the bottom of the SSD.
  9. Acer Aspire a515-46 SSD Replacement, Replace SSD 2 of 3: stap 9, afbeelding 1 van 2 Acer Aspire a515-46 SSD Replacement, Replace SSD 2 of 3: stap 9, afbeelding 2 van 2
    • Pull the SSD straight back until it is removed from the socket.
  10. Acer Aspire a515-46 SSD Replacement, Replace SSD 3 of 3: stap 10, afbeelding 1 van 2 Acer Aspire a515-46 SSD Replacement, Replace SSD 3 of 3: stap 10, afbeelding 2 van 2
    • Insert the new SSD into the socket, making sure that the notch is on the right side of the SSD.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Am Persand
211 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 534
