Inleiding
Do not proceed with this guide unless you are prepared to clean and re-apply thermal compound. For more information, please refer to the How to Clean and Apply Thermal Compound guide.
Wat je nodig hebt
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
Using the plastic tabs, lift the hard drive slightly and pull to the left.
Remove the rubber mounting brackets from the hard drive.
Thank you for the post. This is exactly what I needed. My laptop however doesn't have the plastic mounting bracket. And I can't find the part number or the equivalent part. Anything I find belongs to other Acer models and seem to be a diff size. Would you be kind enough to mention the part number , or a link to it online , or at the dimension of the bracket
Locate the memory modules at the bottom right quadrant of the motherboard. The two memory modules are slightly stacked on top of each other.
Using both hands, pull the clasps away simultaneously in order to release the memory modules.
Locate the wireless card on the top left quadrant. It should have two antenna cables connected to it, one white and one black.
With a pair of blunt tweezers, firmly grasp each antenna head and detach it by lifting straight up.
Use a Phillips Head size #1 screwdriver to remove the two silver-colored 10mm Phillips Head screws securing the fan to the motherboard.
Use a pair of blunt tweezers to gently push on the 3-pin connector. This disconnects the fan from the motherboard.
With all major components removed, proceed to locate the connectors marked on the photograph:
Power jack harness connector.
Ribbon cables.
Display cable connector.
Keyboard connector.
Disconnect the power jack harness from the motherboard by pushing on the tabs with a pair of blunt tweezers.
Use a plastic opening tool to pry open the locks, then pull the ribbon cables out.
You can follow the steps in reverse to reassemble your device, but you should not re-seat the heat sink and fan without cleaning and re-applying the thermal compound.
2Gids Commentaar
Is it necessary to remove everything especially heat sink if I want to replace only keyboard?
