Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Acer Aspire - V5-572, V5-572G
How to disassemble the Laptop and replace the Wi-Fi Card.
Video overzicht
  1. Switch-off the Laptop.
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. If there is a plastic storage tray in the laptop, remove it.
    • If there is a plastic storage tray in the laptop, remove it.
  3. Essentiële Electronica Toolkit
    Kleine toolkit. Grote dromen.
    Shop Toolkits
    Essentiële
    Electronica
    Toolkit
    Shop Toolkits
  4. Starting from the SD Memory Card hole, start prying between the top and bottom cases. Use plastic tools to avoid damaging the cover. Remove the bottom case.
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  5. Disconnect the battery immediately for a safer repair.
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  6. Remove 1x screw and disconnect the two antenna coaxial cables. Remove the Wi-Fi card from the slot. Remove the Wi-Fi card from the slot.
    • Remove 1x screw and disconnect the two antenna coaxial cables.
    • Remove the Wi-Fi card from the slot.
Conclusie
ZFix
170.887 Reputatie
307 handleidingen geschreven
Master Techs Lid van Master Techs
Community
293 Leden
928 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 3,218
