Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
If there is a plastic storage tray in the laptop, remove it.
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Pull the battery connector away from the hard drive to disconnect it.
This model have 1x Memory Slot.
You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
6 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
