Inleiding
Acer Aspire - V5-572, V5-572G
We will show you how to open the Laptop and install a new RAM Module.
Wat je nodig hebt
Video overzicht
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
I have to agree that this is extremely complicated and intense.
There is no way your average user should be doing this and the average user should be able to replace the battery!!
Like everything in the computer world, hardware or software, ease of use is no longer even a consideration!!
Technical Support Bots are the rule and they rarely are up to date with the pages on the website!!
Sucks!!
This model have 1x Memory Slot.
You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
6 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
