Inleiding
Acer Aspire - V5-572, V5-572G
We will show you how to open the Laptop and install a new RAM Module.
Video overzicht
  1. Switch-off the Laptop.
    • Switch-off the Laptop.
    • Remove 17x Philips screws.
  2. Start opening from the SD Memory Card hole
    • Start opening from the SD Memory Card hole
    • Use plastic tools to avoid damaging the cover.
    • Before doing anything, disconnect the battery.
    • This model have 1x Memory Slot.
    • You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
Conclusie
4 andere personen hebben deze handleiding voltooid.
ZFix
161.579 Reputatie
304 handleidingen geschreven
Master Techs Lid van Master Techs
Community
279 Leden
772 handleidingen geschreven
Één commentaar
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
Indi Shukla - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 7
Afgelopen 7 Dagen: 32
Afgelopen 30 Dagen: 151
Altijd: 13,535
