Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
If there is a plastic storage tray in the laptop, remove it.
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Pull the battery connector away from the hard drive to disconnect it.
Remove the single Phillips 0 screw securing the battery.
Disconnect the SATA Cable from the Mother Board.
Take out the HDD and remove the SATA cable from it.
Now you can change / upgrade your HDD.
Remove 1x screw and disconnect the two antenna coaxial cables.
Remove the Wi-Fi card from the slot.
Disconnect the Fan cable.
Remove the three screws from the CPU cooler and one from the Fan module.
Disconnect one by one:
LCD Display flex cable
DC Jack cable
USB Board flex cable
Touch pad flex cable
Keyboard flex cable
Disconnect the Loudspeakers and the Microphone cables.
Remove 6x Phillips screws, 3x from the Main board and 3x from the hinge.
Open a little the laptop to open the hinge.
By hand, open the hinge to the end.
Één andere persoon heeft deze handleiding voltooid.
