Inleiding
How to disassemble Acer Aspire - V5-572, V5-572G and remove the Main board.
Wat je nodig hebt
Video overzicht
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
I have to agree that this is extremely complicated and intense.
There is no way your average user should be doing this and the average user should be able to replace the battery!!
Like everything in the computer world, hardware or software, ease of use is no longer even a consideration!!
Technical Support Bots are the rule and they rarely are up to date with the pages on the website!!
Sucks!!
Remove the battery
Disconnect the SATA Cable from the Mother Board.
Take out the HDD and remove the SATA cable from it.
Now you can change / upgrade your HDD.
Remove 1x screw and disconnect the two antenna coaxial cables.
Remove the Wi-Fi card from the slot.
Disconnect the Fan cable.
Remove the three screws from the CPU cooler and one from the Fan module.
Disconnect one by one:
LCD Display flex cable
DC Jack cable
USB Board flex cable
Touch pad flex cable
Keyboard flex cable
Ich hatte Probleme beim Entfernen des “USB Board flex cable”. Man muss vorsichtig den weissen “Schließer” in Richtung Kabel etwas öffnen. Nicht ganz herausziehen (obwohl das sehr leicht passiert). Das Kabel muss sich leicht herausziehen lassen. Beim Zusammenbau dann umgekehrt: Zuerst das Kabel einstecken, dann vorsichtig den Schließer wieder eindrücken.
Één andere persoon heeft deze handleiding voltooid.
