Ga door naar hoofdinhoud
Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement
Wat je nodig hebt
Video overzicht
  1. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: stap 2, afbeelding 1 van 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: stap 3, afbeelding 1 van 3 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: stap 3, afbeelding 2 van 3 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: stap 3, afbeelding 3 van 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery
  7. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: stap 7, afbeelding 1 van 3 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: stap 7, afbeelding 2 van 3 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: stap 7, afbeelding 3 van 3
    • Disconnect the Loudspeakers cable.
    • There are two modules with loudspeakers, connected with one wire.
    • Unscrew the screws and remove the Loudspeaker modules together with the cable.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
ZFix
191.182 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.521 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 25
Altijd: 2,159
