Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
If there is a plastic storage tray in the laptop, remove it.
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Pull the battery connector away from the hard drive to disconnect it.
Disconnect the Fan cable.
Remove the three screws from the CPU cooler and one from the Fan module.
Use a lint-free cloth to clean the old thermal compound.
Use again cloth with isopropyl alcohol to clean the Thermal surface.
Remove the 3x Phillips screws and open the Fan case.
Use a soft brush and clean the Fan and the Cooler.
Use the same technic to clean the surface of the processor from the old thermal compound
Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
