Ga door naar hoofdinhoud
Acer Aspire V5-572 Bottom Cover Replacement
Wat je nodig hebt
Video overzicht
  1. Acer Aspire V5-572 Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572 Bottom Cover Replacement: stap 2, afbeelding 1 van 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572 Bottom Cover Replacement: stap 3, afbeelding 1 van 3 Acer Aspire V5-572 Bottom Cover Replacement: stap 3, afbeelding 2 van 3 Acer Aspire V5-572 Bottom Cover Replacement: stap 3, afbeelding 3 van 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
    Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
    razbojnikkuro - Antwoord
    I have to agree that this is extremely complicated and intense.
    There is no way your average user should be doing this and the average user should be able to replace the battery!!
    Like everything in the computer world, hardware or software, ease of use is no longer even a consideration!!
    Technical Support Bots are the rule and they rarely are up to date with the pages on the website!!
    Sucks!!
    andy.cox - Antwoord
  4. Acer Aspire V5-572 Bottom Cover Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
ZFix
194.093 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
327 Leden
1.699 handleidingen geschreven
Één opmerking
Hello, I'm just trying to find this bottom casing -- anywhere -- and cannot seem to be able to find or purchase one. Often the wrong one comes up when I search (as evidenced by vents in the wrong places). Any ideas? Thanks in advance.
bellemcc - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 4,003
