Ga door naar hoofdinhoud
Acer Aspire V5-571P-6815 Charging Port Replacement
Wat je nodig hebt
  1. Acer Aspire V5-571P-6815 Charging Port Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer and unplug all power.
  2. Acer Aspire V5-571P-6815 Charging Port Replacement: stap 2, afbeelding 1 van 2 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Slide the locking latch to the right and hold while pulling the battery out with your other hand.
  3. Acer Aspire V5-571P-6815 Charging Port Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Remove the two 7mm Phillips #00 screws from the bottom of the laptop.
  4. Acer Aspire V5-571P-6815 Charging Port Replacement: stap 4, afbeelding 1 van 3 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 4, afbeelding 2 van 3 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 4, afbeelding 3 van 3
    • Insert a plastic opening tool underneath the keyboard and pry upwards.
    • Slide the plastic opening tool around the perimeter to free the keyboard.
    • Flip the keyboard over and onto the palm rest.
  5. Acer Aspire V5-571P-6815 Charging Port Replacement: stap 5, afbeelding 1 van 3 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 5, afbeelding 2 van 3 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 5, afbeelding 3 van 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    • Remove the keyboard from the laptop.
  6. Acer Aspire V5-571P-6815 Charging Port Replacement, Charging Port: stap 6, afbeelding 1 van 1
    • Remove the six 6mm Phillips #0 screws from underneath the keyboard.
  7. Acer Aspire V5-571P-6815 Charging Port Replacement: stap 7, afbeelding 1 van 1
    • Remove the sixteen 6mm Phillips #0 screws from the bottom cover.
  8. Acer Aspire V5-571P-6815 Charging Port Replacement: stap 8, afbeelding 1 van 3 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 8, afbeelding 2 van 3 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 8, afbeelding 3 van 3
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
    • Pull the ribbon cable from the socket.
  9. Acer Aspire V5-571P-6815 Charging Port Replacement: stap 9, afbeelding 1 van 2 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 9, afbeelding 2 van 2
  10. Acer Aspire V5-571P-6815 Charging Port Replacement: stap 10, afbeelding 1 van 3 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 10, afbeelding 2 van 3 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 10, afbeelding 3 van 3
    • Use a plastic opening tool to pry up the palm rest from the laptop body.
    • Remove the palm rest from the laptop.
  11. Acer Aspire V5-571P-6815 Charging Port Replacement: stap 11, afbeelding 1 van 2 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 11, afbeelding 2 van 2
    • Disconnect the charging port cable from the motherboard.
    • You might have to remove some electrical tape that is in the way.
  12. Acer Aspire V5-571P-6815 Charging Port Replacement: stap 12, afbeelding 1 van 3 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 12, afbeelding 2 van 3 Acer Aspire V5-571P-6815 Charging Port Replacement: stap 12, afbeelding 3 van 3
    • Lift the charging port up and out of the laptop.
Conclusie
Follow the steps in reverse with a new cable.
Één andere persoon heeft deze handleiding voltooid.
Gordon Tran
225 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G4, Liner Spring 2018 Lid van UW Tacoma, Team S1-G4, Liner Spring 2018
UWT-LINER-S18S1G4
5 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 32
Altijd: 5,772
