Ga door naar hoofdinhoud
Acer Aspire V5-571-6891 Motherboard Replacement
Wat je nodig hebt
  1. Acer Aspire V5-571-6891 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
  2. Acer Aspire V5-571-6891 Motherboard Replacement: stap 2, afbeelding 1 van 2 Acer Aspire V5-571-6891 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery out of the battery slot.
  3. Acer Aspire V5-571-6891 Motherboard Replacement, RAM: stap 3, afbeelding 1 van 1
    • Unscrew the two RAM 6mm cover screws.
    • Use a PH1 screw bit.
  4. Acer Aspire V5-571-6891 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Pop the RAM cover off.
    • Use the plastic opening tool.
  5. Acer Aspire V5-571-6891 Motherboard Replacement: stap 5, afbeelding 1 van 3 Acer Aspire V5-571-6891 Motherboard Replacement: stap 5, afbeelding 2 van 3 Acer Aspire V5-571-6891 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Use either the spudger or your fingers to pinch the clips away from the RAM chip on either side of each chip.
    • The chip should pop up.
    • The clips break easily.
    • Slide the RAM memory chips out of the slots.
  6. Acer Aspire V5-571-6891 Motherboard Replacement, Keyboard: stap 6, afbeelding 1 van 1
    • Remove the two 6mm PH1 screws from the bottom of the laptop.
  7. Acer Aspire V5-571-6891 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Use the spudger, push the two tabs, located in the battery slot, through their slots to release the keyboard.
    • Do this with the computer slightly open for ease.
  8. Acer Aspire V5-571-6891 Motherboard Replacement: stap 8, afbeelding 1 van 2 Acer Aspire V5-571-6891 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Open the laptop.
    • Start top of the keyboard and use the opening tool to pop the remaining tabs around the keyboard loose.
    • The keyboard can be flipped onto its face once removed.
  9. Acer Aspire V5-571-6891 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Use the spudger and slide the grey tabs on either side of the keyboard wires away from the white plastic.
  10. Acer Aspire V5-571-6891 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Disconnect the keyboard by pulling the blue tape on the wire strip.
  11. Acer Aspire V5-571-6891 Motherboard Replacement, Hard Disk Drive (HDD): stap 11, afbeelding 1 van 1
    • Remove the five 6mm PH1 screws beneath the keyboard.
  12. Acer Aspire V5-571-6891 Motherboard Replacement: stap 12, afbeelding 1 van 2 Acer Aspire V5-571-6891 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Use the spudger to pop the gray tab up and away from the far left wire strip.
    • Disconnect the wire strip by pulling the blue tab loose.
  13. Acer Aspire V5-571-6891 Motherboard Replacement: stap 13, afbeelding 1 van 2 Acer Aspire V5-571-6891 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Use the spudger to pop the white tab up away from the wire strip located at the top left corner of the mouse pad.
    • Disconnect the wire strip by pulling the blue tab.
  14. Acer Aspire V5-571-6891 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Close the laptop.
    • Remove the remaining 18 6mm PH1 screws from the bottom cover of the laptop.
  15. Acer Aspire V5-571-6891 Motherboard Replacement: stap 15, afbeelding 1 van 3 Acer Aspire V5-571-6891 Motherboard Replacement: stap 15, afbeelding 2 van 3 Acer Aspire V5-571-6891 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Use the opening tool to separate the back of the laptop from the inside cover.
    • Open the computer and remove the inside cover.
  16. Acer Aspire V5-571-6891 Motherboard Replacement: stap 16, afbeelding 1 van 3 Acer Aspire V5-571-6891 Motherboard Replacement: stap 16, afbeelding 2 van 3 Acer Aspire V5-571-6891 Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Lift the HDD out of the base and use the opening tool to disconnect the HDD from the motherboard wire.
  17. Acer Aspire V5-571-6891 Motherboard Replacement, CPU Fan: stap 17, afbeelding 1 van 2 Acer Aspire V5-571-6891 Motherboard Replacement, CPU Fan: stap 17, afbeelding 2 van 2
    • Slide the optical disc drive out of the slot to disconnect it from the motherboard.
    • Unscrew the main 3.5mm PH1 screw from the motherboard.
  18. Acer Aspire V5-571-6891 Motherboard Replacement: stap 18, afbeelding 1 van 3 Acer Aspire V5-571-6891 Motherboard Replacement: stap 18, afbeelding 2 van 3 Acer Aspire V5-571-6891 Motherboard Replacement: stap 18, afbeelding 3 van 3
    • Unscrew the 3.5mm PH1 screw from the Wireless Lan chip.
    • Use the opening tool to pop both wires off of the Wireless Lan chip.
    • Pull the Wirelss Lan Chip to remove it from the motherboard.
  19. Acer Aspire V5-571-6891 Motherboard Replacement: stap 19, afbeelding 1 van 2 Acer Aspire V5-571-6891 Motherboard Replacement: stap 19, afbeelding 2 van 2
    • Pull the tape covering the wires for the Wireless Lan chip up.
    • Pull the black and white wires loose.
  20. Acer Aspire V5-571-6891 Motherboard Replacement: stap 20, afbeelding 1 van 2 Acer Aspire V5-571-6891 Motherboard Replacement: stap 20, afbeelding 2 van 2
    • Pull up the tape securing the optical wires to the motherboard.
    • Disconnect the wire plug-in from the motherboard.
  21. Acer Aspire V5-571-6891 Motherboard Replacement: stap 21, afbeelding 1 van 2 Acer Aspire V5-571-6891 Motherboard Replacement: stap 21, afbeelding 2 van 2
    • Unscrew the 3.5mm PH1 screw securing the optical disk drive to motherboard connector.
    • Pull the connector to disconnect it from the motherboard.
  22. Acer Aspire V5-571-6891 Motherboard Replacement: stap 22, afbeelding 1 van 1
    • Flip the motherboard up towards the screen to access the underside.
    • There are still wires connected to the motherboard.
  23. Acer Aspire V5-571-6891 Motherboard Replacement: stap 23, afbeelding 1 van 3 Acer Aspire V5-571-6891 Motherboard Replacement: stap 23, afbeelding 2 van 3 Acer Aspire V5-571-6891 Motherboard Replacement: stap 23, afbeelding 3 van 3
    • Use the spudger to disconnect the remaining three wires from the motherboard.
    • Once the wires are disconnected, the motherboard is completely disconnected from the laptop frame.
  24. Acer Aspire V5-571-6891 Motherboard Replacement: stap 24, afbeelding 1 van 1
    • Unscrew the three PH1 screws connecting the CPU fan to the motherboard.
    • The three screws are permanently attached to the CPU fan assembly.
  25. Acer Aspire V5-571-6891 Motherboard Replacement: stap 25, afbeelding 1 van 2 Acer Aspire V5-571-6891 Motherboard Replacement: stap 25, afbeelding 2 van 2
    • On the side opposite the CPU fan screws, pull loose the tape securing the fan assembly to the motherboard.
    • This is the same tape that covered the Wireless Lan chip black and white wires.
    • The CPU fan can now be separated from the motherboard.
  26. Acer Aspire V5-571-6891 Motherboard Replacement, Motherboard: stap 26, afbeelding 1 van 1
    • The motherboard can be replaced once disconnected from the CPU cooling fan.
Conclusie
Josh Focht
244 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 26
Altijd: 1,612
