Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip laptop over so that the back is facing upward.
Push switch to the right.
Pull battery away from the laptop.
Use a #0 Phillips head screw driver to remove all of the screws.
Flip laptop back over.
Open the laptop.
Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
Gently lift keyboard.
Disconnect keyboard from the laptop.
Disconnect the two ribbon cables at the near left.
Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
Use a prying tool to remove the upper cover.
Locate the hard drive.
Lift the hard drive.
Disconnect hard drive.
Één andere persoon heeft deze handleiding voltooid.
