Ga door naar hoofdinhoud
Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement
Wat je nodig hebt
Video overzicht
  1. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Keyboard: stap 1, afbeelding 1 van 3 Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Keyboard: stap 1, afbeelding 2 van 3 Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: stap 2, afbeelding 1 van 3 Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: stap 2, afbeelding 2 van 3 Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: stap 2, afbeelding 3 van 3
  3. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Upper  Cover: stap 3, afbeelding 1 van 3 Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Upper  Cover: stap 3, afbeelding 2 van 3 Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Upper  Cover: stap 3, afbeelding 3 van 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  4. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: stap 4, afbeelding 1 van 3 Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: stap 4, afbeelding 2 van 3 Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: stap 4, afbeelding 3 van 3
    • Carefully separate the upper cover and remove it.
  5. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Wi-Fi Half Mini PCIe card: stap 5, afbeelding 1 van 2 Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Wi-Fi Half Mini PCIe card: stap 5, afbeelding 2 van 2
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
Conclusie
ZFix
191.055 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.506 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 2,777
