Ga door naar hoofdinhoud
Acer Aspire V5-571 Upper Cover Replacement
Wat je nodig hebt
  1. Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: stap 1, afbeelding 1 van 3 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: stap 1, afbeelding 2 van 3 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Upper  Cover Replacement: stap 2, afbeelding 1 van 3 Acer Aspire V5-571 Upper  Cover Replacement: stap 2, afbeelding 2 van 3 Acer Aspire V5-571 Upper  Cover Replacement: stap 2, afbeelding 3 van 3
  3. Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: stap 3, afbeelding 1 van 3 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: stap 3, afbeelding 2 van 3 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: stap 3, afbeelding 3 van 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: stap 4, afbeelding 1 van 3 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: stap 4, afbeelding 2 van 3 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: stap 4, afbeelding 3 van 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Upper  Cover Replacement: stap 5, afbeelding 1 van 3 Acer Aspire V5-571 Upper  Cover Replacement: stap 5, afbeelding 2 van 3 Acer Aspire V5-571 Upper  Cover Replacement: stap 5, afbeelding 3 van 3
    • Carefully separate the upper cover and remove it.
Conclusie
ZFix
194.072 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
327 Leden
1.697 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 3,116
