Ga door naar hoofdinhoud
Acer Aspire V5-571 Optical Drive Replacement
Wat je nodig hebt
Video overzicht
  1. Acer Aspire V5-571 Optical Drive Replacement, Keyboard: stap 1, afbeelding 1 van 3 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: stap 1, afbeelding 2 van 3 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Optical Drive Replacement: stap 2, afbeelding 1 van 3 Acer Aspire V5-571 Optical Drive Replacement: stap 2, afbeelding 2 van 3 Acer Aspire V5-571 Optical Drive Replacement: stap 2, afbeelding 3 van 3
  3. Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: stap 3, afbeelding 1 van 3 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: stap 3, afbeelding 2 van 3 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: stap 3, afbeelding 3 van 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
Conclusie
4 andere personen hebben deze handleiding voltooid.
ZFix
191.308 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.532 handleidingen geschreven
2 opmerkingen
Is it safe to use with the optical drive out? I just took it out and I don't get the part until next week but I need to use my laptop... can I use it?
I needed to replace it because I dropped my laptop off the arm of the sofa with the drive open and falling on that side too.
Vianca - Antwoord
Is it safe to use the laptop with the optical drive out?
Vianca - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 5,117
