Ga door naar hoofdinhoud
Acer Aspire V5-571 Optical Drive Replacement
Wat je nodig hebt
Video overzicht
  1. Acer Aspire V5-571 Optical Drive Replacement, Keyboard: stap 1, afbeelding 1 van 3 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: stap 1, afbeelding 2 van 3 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Optical Drive Replacement: stap 2, afbeelding 1 van 3 Acer Aspire V5-571 Optical Drive Replacement: stap 2, afbeelding 2 van 3 Acer Aspire V5-571 Optical Drive Replacement: stap 2, afbeelding 3 van 3
  3. Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: stap 3, afbeelding 1 van 3 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: stap 3, afbeelding 2 van 3 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: stap 3, afbeelding 3 van 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
Conclusie
4 andere personen hebben deze handleiding voltooid.
ZFix
194.147 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
326 Leden
1.672 handleidingen geschreven
2Gids Commentaar
Is it safe to use with the optical drive out? I just took it out and I don't get the part until next week but I need to use my laptop... can I use it?
I needed to replace it because I dropped my laptop off the arm of the sofa with the drive open and falling on that side too.
Vianca - Antwoord
Is it safe to use the laptop with the optical drive out?
Vianca - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 5,209
