Ga door naar hoofdinhoud
Acer Aspire V5-571 Mother Board Replacement
Wat je nodig hebt
Video overzicht
  1. Acer Aspire V5-571 Mother Board Replacement, Keyboard: stap 1, afbeelding 1 van 3 Acer Aspire V5-571 Mother Board Replacement, Keyboard: stap 1, afbeelding 2 van 3 Acer Aspire V5-571 Mother Board Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Mother Board Replacement: stap 2, afbeelding 1 van 3 Acer Aspire V5-571 Mother Board Replacement: stap 2, afbeelding 2 van 3 Acer Aspire V5-571 Mother Board Replacement: stap 2, afbeelding 3 van 3
  3. Acer Aspire V5-571 Mother Board Replacement, Optical Drive: stap 3, afbeelding 1 van 3 Acer Aspire V5-571 Mother Board Replacement, Optical Drive: stap 3, afbeelding 2 van 3 Acer Aspire V5-571 Mother Board Replacement, Optical Drive: stap 3, afbeelding 3 van 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Mother Board Replacement, Upper  Cover: stap 4, afbeelding 1 van 3 Acer Aspire V5-571 Mother Board Replacement, Upper  Cover: stap 4, afbeelding 2 van 3 Acer Aspire V5-571 Mother Board Replacement, Upper  Cover: stap 4, afbeelding 3 van 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Mother Board Replacement: stap 5, afbeelding 1 van 3 Acer Aspire V5-571 Mother Board Replacement: stap 5, afbeelding 2 van 3 Acer Aspire V5-571 Mother Board Replacement: stap 5, afbeelding 3 van 3
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 Mother Board Replacement, HDD (Hard Disk Drive): stap 6, afbeelding 1 van 3 Acer Aspire V5-571 Mother Board Replacement, HDD (Hard Disk Drive): stap 6, afbeelding 2 van 3 Acer Aspire V5-571 Mother Board Replacement, HDD (Hard Disk Drive): stap 6, afbeelding 3 van 3
  7. Acer Aspire V5-571 Mother Board Replacement, Wi-Fi Half Mini PCIe card: stap 7, afbeelding 1 van 2 Acer Aspire V5-571 Mother Board Replacement, Wi-Fi Half Mini PCIe card: stap 7, afbeelding 2 van 2
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 Mother Board Replacement, Mother Board: stap 8, afbeelding 1 van 3 Acer Aspire V5-571 Mother Board Replacement, Mother Board: stap 8, afbeelding 2 van 3 Acer Aspire V5-571 Mother Board Replacement, Mother Board: stap 8, afbeelding 3 van 3
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 Mother Board Replacement: stap 9, afbeelding 1 van 3 Acer Aspire V5-571 Mother Board Replacement: stap 9, afbeelding 2 van 3 Acer Aspire V5-571 Mother Board Replacement: stap 9, afbeelding 3 van 3
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 Mother Board Replacement: stap 10, afbeelding 1 van 3 Acer Aspire V5-571 Mother Board Replacement: stap 10, afbeelding 2 van 3 Acer Aspire V5-571 Mother Board Replacement: stap 10, afbeelding 3 van 3
    • Carefully pick up the Mother board and disconnect the Battery cable.
Conclusie
3 andere personen hebben deze handleiding voltooid.
ZFix
191.308 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.535 handleidingen geschreven
Één opmerking
I can’t seem to get the system to reboot after replacing two motherboards. Is there a little trick about replacing or reseating the motherboard properly? Is the black cloth tape over the fan exhaust important?
fun.fong.jr - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 4,314
