Ga door naar hoofdinhoud
Acer Aspire V5-473P-5602 Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire V5-473P-5602 Keyboard Replacement, Back Panel: stap 1, afbeelding 1 van 2 Acer Aspire V5-473P-5602 Keyboard Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Keyboard Replacement, Battery: stap 2, afbeelding 1 van 2 Acer Aspire V5-473P-5602 Keyboard Replacement, Battery: stap 2, afbeelding 2 van 2
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Keyboard Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Remove the four Phillips #0 screws from the hard drive.
  6. Acer Aspire V5-473P-5602 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Gently unplug the hard drive connector.
  7. Acer Aspire V5-473P-5602 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the hard drive from the laptop.
  8. Acer Aspire V5-473P-5602 Keyboard Replacement, Fan: stap 8, afbeelding 1 van 2 Acer Aspire V5-473P-5602 Keyboard Replacement, Fan: stap 8, afbeelding 2 van 2
    • Remove the five Phillips #0 screws that are holding the fan down to the base.
  9. Acer Aspire V5-473P-5602 Keyboard Replacement: stap 9, afbeelding 1 van 2 Acer Aspire V5-473P-5602 Keyboard Replacement: stap 9, afbeelding 2 van 2
    • Gently unplug the cables from the Wi-Fi card.
  10. Acer Aspire V5-473P-5602 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the fan from the laptop.
  11. Acer Aspire V5-473P-5602 Keyboard Replacement, Secondary Cooling Fan: stap 11, afbeelding 1 van 2 Acer Aspire V5-473P-5602 Keyboard Replacement, Secondary Cooling Fan: stap 11, afbeelding 2 van 2
    • Unplug the cable that connects to the fan to motherboard.
  12. Acer Aspire V5-473P-5602 Keyboard Replacement: stap 12, afbeelding 1 van 1
    • Remove the two Phillips #0 screws that secure the fan to the base.
  13. Acer Aspire V5-473P-5602 Keyboard Replacement, Motherboard: stap 13, afbeelding 1 van 2 Acer Aspire V5-473P-5602 Keyboard Replacement, Motherboard: stap 13, afbeelding 2 van 2
    • Remove the ten Phillips #0 screws that attach the motherboard to the keyboard.
  14. Acer Aspire V5-473P-5602 Keyboard Replacement: stap 14, afbeelding 1 van 3 Acer Aspire V5-473P-5602 Keyboard Replacement: stap 14, afbeelding 2 van 3 Acer Aspire V5-473P-5602 Keyboard Replacement: stap 14, afbeelding 3 van 3
    • Unplug the two data cables that attach the keyboard to the motherboard.
    • Remove the motherboard from the laptop.
  15. Acer Aspire V5-473P-5602 Keyboard Replacement, Keyboard: stap 15, afbeelding 1 van 1
    • Pull the clear plastic sheet from the top of the metal upper part of the keyboard.
  16. Acer Aspire V5-473P-5602 Keyboard Replacement: stap 16, afbeelding 1 van 2 Acer Aspire V5-473P-5602 Keyboard Replacement: stap 16, afbeelding 2 van 2
    • Detach the keyboard clips using an iFixit opening tool.
  17. Acer Aspire V5-473P-5602 Keyboard Replacement: stap 17, afbeelding 1 van 1
    • Remove the keyboard from the laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Noora Al-loos
283 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 1,354
