Ga door naar hoofdinhoud
Acer Aspire V5-131-2680 Touchpad Replacement
Wat je nodig hebt
  1. Acer Aspire V5-131-2680 Touchpad Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Touchpad Replacement: stap 2, afbeelding 1 van 2 Acer Aspire V5-131-2680 Touchpad Replacement: stap 2, afbeelding 2 van 2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Touchpad Replacement, Touchpad: stap 3, afbeelding 1 van 1
    • Remove the twenty 6 mm screws using a Phillips #00 screwdriver.
    • Unplug the battery and disconnect all the components connected to the motherboard.
    • Pry open the bottom of the laptop using the pry tool.
  4. Acer Aspire V5-131-2680 Touchpad Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the larger ribbon cable that connects from the motherboard to the keyboard by gently pulling on the end that attaches to the keyboard.
  5. Acer Aspire V5-131-2680 Touchpad Replacement: stap 5, afbeelding 1 van 1
    • Remove the tape that is holding the smaller ribbon to the touchpad. Gently disconnect the smaller ribbon by pulling on it.
  6. Acer Aspire V5-131-2680 Touchpad Replacement: stap 6, afbeelding 1 van 1
    • Once both of the ribbons are disconnected, the side with the keyboard will detach from the rest of the computer.
    • Now we can move the keyboard side without the rest of the laptop.
  7. Acer Aspire V5-131-2680 Touchpad Replacement: stap 7, afbeelding 1 van 1
    • Remove all of the M2 x 3 Phillips screws that are holding the keyboard in place.
    • Some screws will be located under a piece of tape. Remove the tape prior to unscrewing these screws.
  8. Acer Aspire V5-131-2680 Touchpad Replacement: stap 8, afbeelding 1 van 1
    • Remove the keyboard from the frame by pulling up on the keyboard.
    • With the keyboard out of the way, we will be able to access the touchpad.
  9. Acer Aspire V5-131-2680 Touchpad Replacement: stap 9, afbeelding 1 van 2 Acer Aspire V5-131-2680 Touchpad Replacement: stap 9, afbeelding 2 van 2
    • Remove the touchpad from the frame by pushing up on the touchpad.
Conclusie
Mauricio Moreno
601 Reputatie
5 handleidingen geschreven
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Lid van CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 223
