Ga door naar hoofdinhoud
Acer Aspire V5-131-2629 RAM Replacement
Wat je nodig hebt
  1. Acer Aspire V5-131-2629 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 RAM Replacement: stap 2, afbeelding 1 van 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 RAM Replacement: stap 3, afbeelding 1 van 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 RAM Replacement: stap 4, afbeelding 1 van 2 Acer Aspire V5-131-2629 RAM Replacement: stap 4, afbeelding 2 van 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 RAM Replacement, Cover: stap 5, afbeelding 1 van 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 RAM Replacement: stap 6, afbeelding 1 van 2 Acer Aspire V5-131-2629 RAM Replacement: stap 6, afbeelding 2 van 2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 RAM Replacement, RAM: stap 7, afbeelding 1 van 1
    • Using your finger, press the small tab on each side of the memory card.
    • The memory card will eject at a 45 degree angle.
  8. Acer Aspire V5-131-2629 RAM Replacement: stap 8, afbeelding 1 van 1
    • Pull the memory cards out from the laptop.
Conclusie
Nicholas Vassiliadis
85 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 Lid van UMass Dartmouth, Team S1-G3, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 564
