Ga door naar hoofdinhoud
Acer Aspire V5-131-2629 Hard Drive Replacement
Wat je nodig hebt
  1. Acer Aspire V5-131-2629 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Hard Drive Replacement: stap 4, afbeelding 1 van 2 Acer Aspire V5-131-2629 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Hard Drive Replacement, Cover: stap 5, afbeelding 1 van 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Hard Drive Replacement: stap 6, afbeelding 1 van 2 Acer Aspire V5-131-2629 Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Hard Drive Replacement, Hard Drive: stap 7, afbeelding 1 van 1
    • Locate the large blue hard drive on the left side on the computer.
  8. Acer Aspire V5-131-2629 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Gently pull out the ribbon cable on the computer-attached end.
  9. Acer Aspire V5-131-2629 Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Completely remove the hard drive from the hard drive bay.
  10. Acer Aspire V5-131-2629 Hard Drive Replacement: stap 10, afbeelding 1 van 2 Acer Aspire V5-131-2629 Hard Drive Replacement: stap 10, afbeelding 2 van 2
    • Remove the two screws on the side of the hard drive cage.
  11. Acer Aspire V5-131-2629 Hard Drive Replacement: stap 11, afbeelding 1 van 2 Acer Aspire V5-131-2629 Hard Drive Replacement: stap 11, afbeelding 2 van 2
    • Pull the hard drive cage from the hard drive to separate the two.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Nicole B Bosse
175 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 Lid van UMass Dartmouth, Team S1-G3, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 27
Altijd: 1,639
