Ga door naar hoofdinhoud
Acer Aspire V5-122P-0889 Network Card Replacement
Wat je nodig hebt
  1. Acer Aspire V5-122P-0889 Network Card Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Aspire V5-122P-0889 Network Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
    • Remove the remaining 9 visible screws, which are 5mm in length.
    • Every screw in this laptop can be removed with a Phillips #0 screwdriver.
  2. Acer Aspire V5-122P-0889 Network Card Replacement: stap 2, afbeelding 1 van 2 Acer Aspire V5-122P-0889 Network Card Replacement: stap 2, afbeelding 2 van 2
    • Towards the top right corner of the laptop, there is a rubber piece covering the final screw holding the cover on, as well as a set of pins. Use your fingernail to remove this piece of rubber, and then unscrew the hidden 5mm screw.
  3. Acer Aspire V5-122P-0889 Network Card Replacement: stap 3, afbeelding 1 van 2 Acer Aspire V5-122P-0889 Network Card Replacement: stap 3, afbeelding 2 van 2
    • Going around the edges of the laptop, apply light to moderate amounts of pressure away from the laptop to unseat the cover so that it can be removed. Once you have removed the cover, place it face-up in a safe place to avoid getting the inside of the cover dirty.
    • If you are having trouble unseating the cover by hand, a nylon spudger can be run around the perimeter of the laptop to help lift the cover away from the case.
  4. Acer Aspire V5-122P-0889 Network Card Replacement: stap 4, afbeelding 1 van 2 Acer Aspire V5-122P-0889 Network Card Replacement: stap 4, afbeelding 2 van 2
    • Carefully unscrew the two 5mm screws holding the battery in place.
  5. Acer Aspire V5-122P-0889 Network Card Replacement: stap 5, afbeelding 1 van 1
    • Carefully use light upward pressure to unseat the battery from the case, but do not pull on the cord or try and completely remove the battery from the case.
  6. Acer Aspire V5-122P-0889 Network Card Replacement: stap 6, afbeelding 1 van 2 Acer Aspire V5-122P-0889 Network Card Replacement: stap 6, afbeelding 2 van 2
    • Finally, disconnect the battery from the motherboard by undoing the power connector. To undo the connector, simply apply light to moderate pull on the sides of the connector.
  7. Acer Aspire V5-122P-0889 Network Card Replacement, Network Card: stap 7, afbeelding 1 van 2 Acer Aspire V5-122P-0889 Network Card Replacement, Network Card: stap 7, afbeelding 2 van 2
    • Start by removing the antenna cable attached to the network card.
  8. Acer Aspire V5-122P-0889 Network Card Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the two 3mm screws holding the network card in place.
  9. Acer Aspire V5-122P-0889 Network Card Replacement: stap 9, afbeelding 1 van 3 Acer Aspire V5-122P-0889 Network Card Replacement: stap 9, afbeelding 2 van 3 Acer Aspire V5-122P-0889 Network Card Replacement: stap 9, afbeelding 3 van 3
    • Carefully remove the network card by pulling it backwards, out of the slot that it is plugged into.
Conclusie
Katelynn couto
693 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-1, Landers Spring 2016 Lid van UMass Dartmouth, Team 5-1, Landers Spring 2016
UMASSD-LANDERS-S16S5G1
3 Leden
10 handleidingen geschreven
2 opmerkingen
Why you should quite battery to take out the wifi card?
Regards
Vibra - Antwoord
Agreed, no need to pull battery to pull the wifi card, make sure you are ground and you are good to pull and replace.
Cyrus Fox - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 29
Altijd: 1,131
