Inleiding
Your battery is not working? You feel like you are lost?You are wondering how could you possibly check on it or even change it? This guide will teach you how to locate the battery and how to remove it to be replaced.
Wat je nodig hebt
Video overzicht
Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
Remove the remaining 9 visible screws, which are 5mm in length.
5 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Nice guide. Thanks. I have the same model. May I know if it’s normal for my laptop not to work if the battery is removed? I removed the battery pack because they are bulging and not charging anymore. Since it will still take me a long time to buy a replacement and I already have many works pending, can you help me make it work with just the adapter plugged in? I badly need to finish my projects.
