Ga door naar hoofdinhoud
Acer Aspire V5-122P-0468 Touchpad Replacement
Wat je nodig hebt
  1. Acer Aspire V5-122P-0468 Touchpad Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Aspire V5-122P-0468 Touchpad Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Touchpad Replacement: stap 2, afbeelding 1 van 2 Acer Aspire V5-122P-0468 Touchpad Replacement: stap 2, afbeelding 2 van 2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Touchpad Replacement: stap 3, afbeelding 1 van 2 Acer Aspire V5-122P-0468 Touchpad Replacement: stap 3, afbeelding 2 van 2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Touchpad Replacement: stap 4, afbeelding 1 van 3 Acer Aspire V5-122P-0468 Touchpad Replacement: stap 4, afbeelding 2 van 3 Acer Aspire V5-122P-0468 Touchpad Replacement: stap 4, afbeelding 3 van 3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Touchpad Replacement: stap 5, afbeelding 1 van 3 Acer Aspire V5-122P-0468 Touchpad Replacement: stap 5, afbeelding 2 van 3 Acer Aspire V5-122P-0468 Touchpad Replacement: stap 5, afbeelding 3 van 3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Touchpad Replacement, Touchpad: stap 6, afbeelding 1 van 1
    • Use the spudger to pop up the latch on the ZIF connector.
    • Pull out the ribbon cable.
  7. Acer Aspire V5-122P-0468 Touchpad Replacement: stap 7, afbeelding 1 van 3 Acer Aspire V5-122P-0468 Touchpad Replacement: stap 7, afbeelding 2 van 3 Acer Aspire V5-122P-0468 Touchpad Replacement: stap 7, afbeelding 3 van 3
    • Remove the three 2mm PH #0 screws.
    • Lift the metal tape up and off of the mounting bracket.
  8. Acer Aspire V5-122P-0468 Touchpad Replacement: stap 8, afbeelding 1 van 1
    • Remove the metal mounting bracket from the bottom of the touchpad
  9. Acer Aspire V5-122P-0468 Touchpad Replacement: stap 9, afbeelding 1 van 2 Acer Aspire V5-122P-0468 Touchpad Replacement: stap 9, afbeelding 2 van 2
    • Carefully remove the foam pad from along the top edge of touchpad using a spudger.
    • This pad can be reused.
    • Remove the four 2mm PH #0 screws.
  10. Acer Aspire V5-122P-0468 Touchpad Replacement: stap 10, afbeelding 1 van 1
    • Remove the touchpad from the laptop using a spudger.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nat McCormick
801 Reputatie
5 handleidingen geschreven
USF Tampa, Team S16-G1, Boczar Spring 2018 Lid van USF Tampa, Team S16-G1, Boczar Spring 2018
USFT-BOCZAR-S18S16G1
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 35
Altijd: 1,961
