Ga door naar hoofdinhoud
Acer Aspire V3-771G Hard Drive Replacement
Wat je nodig hebt
  1. Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Shut down the laptop.
    • Remove the power charging cord from the laptop.
  2. Acer Aspire V3-771G Hard Drive Replacement: stap 2, afbeelding 1 van 3 Acer Aspire V3-771G Hard Drive Replacement: stap 2, afbeelding 2 van 3 Acer Aspire V3-771G Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Flip the laptop over, and find the battery compartment.
    • Use your fingers to move the orange slider located just below the battery compartment to the right.
    • Do not touch the battery connectors on the battery or laptop.
    • Lift the battery up and remove from the compartment.
  3. Acer Aspire V3-771G Hard Drive Replacement: stap 3, afbeelding 1 van 2 Acer Aspire V3-771G Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Using the screwdriver, remove the nine 8 mm screws from the panel on the back of the laptop.
    • Gently lift the panel up from the open slot, use the opening tools as necessary, to free the panel from the laptop.
  4. Acer Aspire V3-771G Hard Drive Replacement: stap 4, afbeelding 1 van 2 Acer Aspire V3-771G Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Remove the two screws holding the hard drive sled in place.
    • While grounding yourself, gently pull the black tag straight back, not up, to free the hard drive.
  5. Acer Aspire V3-771G Hard Drive Replacement: stap 5, afbeelding 1 van 3 Acer Aspire V3-771G Hard Drive Replacement: stap 5, afbeelding 2 van 3 Acer Aspire V3-771G Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Using the screwdriver, remove the four 4 mm screws from the hard drive sled.
    • Carefully remove the hard drive. A new one may now be installed.
Conclusie
9 andere personen hebben deze handleiding voltooid.
David Walker
341 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-36, Donnelly Fall 2014 Lid van USF Tampa, Team 1-36, Donnelly Fall 2014
USFT-DONNELLY-F14S1G36
1 Lid
1 handleiding geschreven
Één opmerking
Please pardon my inquiry. Is the same replacement can be done to Acer Aspire V3-572P-540V? Any reply will be appreciated.
b6789b - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 13,719
