Ga door naar hoofdinhoud
Wat je nodig hebt
  1. Acer Aspire V3-551-8887 Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Motherboard Replacement: stap 2, afbeelding 1 van 2 Acer Aspire V3-551-8887 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 Motherboard Replacement, USB Ports: stap 3, afbeelding 1 van 1
    • Locate the wifi chip.
  4. Acer Aspire V3-551-8887 Motherboard Replacement: stap 4, afbeelding 1 van 2 Acer Aspire V3-551-8887 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  5. Acer Aspire V3-551-8887 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  6. Acer Aspire V3-551-8887 Motherboard Replacement: stap 6, afbeelding 1 van 2 Acer Aspire V3-551-8887 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  7. Acer Aspire V3-551-8887 Motherboard Replacement: stap 7, afbeelding 1 van 2 Acer Aspire V3-551-8887 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Acer Aspire V3-551-8887 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  9. Acer Aspire V3-551-8887 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • The USB ports can now be removed from the laptop.
  10. Acer Aspire V3-551-8887 Motherboard Replacement, Keyboard: stap 10, afbeelding 1 van 1
    • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
  11. Acer Aspire V3-551-8887 Motherboard Replacement: stap 11, afbeelding 1 van 2 Acer Aspire V3-551-8887 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Use a spudger to gently lift the keyboard.
  12. Acer Aspire V3-551-8887 Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 1
    • Remove the two 10 mm Phillips #1 screws connecting the motherboard to the case.
  13. Acer Aspire V3-551-8887 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Disconnect the 4 ribbon cables connected to the motherboard.
    • Some ribbon cable connections may not be accessible until after beginning to lift.
  14. Acer Aspire V3-551-8887 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Very carefully lift the motherboard.
    • Do not force the board. If stuck, check that the ports on the left are not stuck, that no wires are still attached, and no screws are still in.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Alexander Lazar
342 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-8, Regan Spring 2014 Lid van Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 5,167
