Inleiding
Removing the back panel gives access to most everything else in the laptop.
Wat je nodig hebt
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
