Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
The hard drive on a computer is typically used to access laptop applications. Use this guide to replace broken hard drives, which tend to be the most common laptop component to fail. No complicated manipulation is required.
Onderdelen
Geen onderdelen opgegeven.
  1. To release the battery, slide the orange tab to the right with a spudger. The battery is now released and can be picked up and set to the side.
    • To release the battery, slide the orange tab to the right with a spudger.
    • The battery is now released and can be picked up and set to the side.
  2. Remove the two 5.3 mm Phillips #0 screws. Remove the two 5.3 mm Phillips #0 screws.
    • Remove the two 5.3 mm Phillips #0 screws.
  3. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  4. Pull off the back panel. Pull off the back panel.
    • Pull off the back panel.
  5. Pull the plastic tab on top of the hard drive.
    • Pull the plastic tab on top of the hard drive.
  6. Remove the four 5.3 mm screws that secure the hard drive in the frame. Remove the four 5.3 mm screws that secure the hard drive in the frame.
    • Remove the four 5.3 mm screws that secure the hard drive in the frame.
Conclusie
After replacing the old hard drive, reassemble your device by following these instructions in reverse order.
Maritsa Garcia
800 Reputatie
5 handleidingen geschreven
Baylor, Team S1-G4, Williams Fall 2018 Lid van Baylor, Team S1-G4, Williams Fall 2018
BU-WILLIAMS-F18S1G4
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 219
