Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
The fan in a laptop keeps the device from overheating. If your device is experiencing this common symptom, it's time to replace the fan. Use this guide to replace broken fans in the Acer Aspire V3-551-8469. No complicated manipulation is required, but there are a lot of screws that need to be removed; therefore, be sure to keep track which screw goes where.
  1. To release the battery, slide the orange tab to the right with a spudger. The battery is now released and can be picked up and set to the side.
    • To release the battery, slide the orange tab to the right with a spudger.
    • The battery is now released and can be picked up and set to the side.
  2. Remove the 16 5.3 mm Phillips #0 screws. Remove the three 3 mm Phillips #00 screws. Remove the three 3 mm Phillips #00 screws.
    • Remove the 16 5.3 mm Phillips #0 screws.
    • Remove the three 3 mm Phillips #00 screws.
  3. Remove the back panel, and remove the white cable from the wifi chip using a pair of tweezers. Remove the back panel, and remove the white cable from the wifi chip using a pair of tweezers. Remove the back panel, and remove the white cable from the wifi chip using a pair of tweezers.
    • Remove the back panel, and remove the white cable from the wifi chip using a pair of tweezers.
  4. Using a Phillips head #0 screwdriver, remove the four 5.3 mm screws.
    • Using a Phillips head #0 screwdriver, remove the four 5.3 mm screws.
  5. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  6. Flip the computer over and remove the touchpad cover and keyboard. Be careful doing this since there are two ribbon cables connecting both panels to the motherboard. Be careful doing this since there are two ribbon cables connecting both panels to the motherboard.
    • Flip the computer over and remove the touchpad cover and keyboard.
    • Be careful doing this since there are two ribbon cables connecting both panels to the motherboard.
  7. Disconnect the four ribbon cables. Disconnect the four ribbon cables.
    • Disconnect the four ribbon cables.
  8. Remove the five 5.3 mm Phillips #0 screws.
    • Remove the five 5.3 mm Phillips #0 screws.
  9. Gently lift up the motherboard and slide it out to the right.
    • Gently lift up the motherboard and slide it out to the right.
    • Do not force the board. If stuck, check that the ports on the left are loose, that no wires are still attached, and no screws are still in.
  10. Flip the motherboard over and using a pair of tweezers, remove the cable.
    • Flip the motherboard over and using a pair of tweezers, remove the cable.
  11. Remove the six 2mm Phillips #00  screws. Remove the six 2mm Phillips #00  screws.
    • Remove the six 2mm Phillips #00 screws.
  12. Using a pair of tweezers, remove the cable.
    • Using a pair of tweezers, remove the cable.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Maritsa Garcia
800 Reputatie
5 handleidingen geschreven
Baylor, Team S1-G4, Williams Fall 2018 Lid van Baylor, Team S1-G4, Williams Fall 2018
BU-WILLIAMS-F18S1G4
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 222
