Inleiding
The fan in a laptop keeps the device from overheating. If your device is experiencing this common symptom, it's time to replace the fan. Use this guide to replace broken fans in the Acer Aspire V3-551-8469. No complicated manipulation is required, but there are a lot of screws that need to be removed; therefore, be sure to keep track which screw goes where.
Wat je nodig hebt
To release the battery, slide the orange tab to the right with a spudger.
The battery is now released and can be picked up and set to the side.
Één andere persoon heeft deze handleiding voltooid.
