Inleiding
In this guide you will learn how to disassemble your laptop, remove the battery and replace it.
Wat je nodig hebt
First you will flip your laptop upside down so the battery side is facing up.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Yes don’t need to take cover off -battery can be removed by using a pen/screwdriver to slide the tab to the side & battery releases.
It has a very small image of an arrow with a pen next to it. Very misleading (I tried to push it in first!)
If you wiggle the battery, you can see the battery release tab moves with it :-)
