Inleiding
A working cooling fan in laptops is a critical component because the processor, and graphic IC’s would overheat without it. Fans are a wearout part that will eventually need replacing.
This guide provides simple steps to replace the Fan on the Acer Aspire TimelineX 4830T-6682 using minimal tools that can be acquired locally, or through iFixit. Please make sure and follow the prerequisite procedures.
Wat je nodig hebt
Remove the single screw with a Phillips #0 screwdriver.
Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
After the panel has been removed, locate the RAM. It should be on the lower right.
There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
The battery will be on the side closest to the screen.
Gently lift it out. It will still be attached by white, red, and black wires.
Remove the 3.4mm by 1.9mm screws with a Phillips #0 screwdriver from the fan's heatsink.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
The fans are not generic even though the same fan might be used for several laptop models the frame of the fan might be different. A replacement fan can be purchased online by searching for the laptop model and fan. Here is an example of an Amazon search I did for the Acer Aspire 4830T fan:
https://www.amazon.com/wangpeng-Cooling-...
Best Regards
