Inleiding
If your WiFi module is malfunctioning use this guide to remove and replace the device, to do this you will need a replacement WiFi module, tweezers and a PH 1 Philips head screwdriver. This is a simple process and should not require any in depth knowledge of computers to perform.
Wat je nodig hebt
Power down the laptop.
Turn the laptop over so the bottom is facing up and the battery is facing towards you.
Flip the laptop over and remove screws (PH#1, 8mm length) holding the back cover in place
Remove back cover from your laptop
