Inleiding
In this guide, you will be able to replace your laptop's RAM with step by step help. The RAM is located on the motherboard.
Wat je nodig hebt
Turn laptop so under side is facing up.
Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
Pry open the cover using the Spudger tool.
After removing the motherboard, turn it over so that the back side is facing you.
