Inleiding
Before performing any repairs, make sure the laptop is fully powered off and disconnected from its charger. To repair most parts of the Acer Aspire TimelineU M5-481TG, it is necessary to first remove the keyboard. Be sure to wear a anti-static wrist strap during all laptop repairs. Prying open the keyboard must be done very gently and carefully to ensure that no wires are damaged.
Wat je nodig hebt
With the laptop closed and powered off, place the laptop screen side down.
Turn the laptop so that the hinges are closest to you.
Remove sixteen 6 mm screws from the bottom of the laptop with the Phillips #00 screwdriver.
Hold the keyboard open with one hand to extend the three cables (white, black and copper) still connecting the bottom of the keyboard to the back case.
Use your fingernail to flip up the small retaining flap of each zero insertion force connector and then gently pull each ribbon cable out one at a time.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
my problem is how to replace the keyboard not how to dismantle it
