Ga door naar hoofdinhoud
Acer Aspire TimelineU M5-481TG Audio Drive Replacement
Wat je nodig hebt
  1. Acer Aspire TimelineU M5-481TG Audio Drive Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • With the laptop closed and powered off, place the laptop screen side down.
    • Turn the laptop so that the hinges are closest to you.
    • Remove sixteen 6 mm screws from the bottom of the laptop with the Phillips #00 screwdriver.
  2. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 2, afbeelding 1 van 2 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 2, afbeelding 2 van 2
    • Flip the laptop over and open the lid.
    • Use the plastic opening tool with the half centimeter wide tip to gently separate the bottom case of the laptop from the keyboard.
    • Potential for device damage: Do not apply too much force or you may break the clips.
    • Gently pull the keyboard upwards to a 45 degree angle.
  3. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 3, afbeelding 1 van 3 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 3, afbeelding 2 van 3 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 3, afbeelding 3 van 3
    • Hold the keyboard open with one hand to extend the three cables (white, black and copper) still connecting the bottom of the keyboard to the back case.
    • Be sure you are prying up the hinged retaining flap, not the connector itself.
    • Use your fingernail to flip up the small retaining flap of each zero insertion force connector and then gently pull each ribbon cable out one at a time.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
  4. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 4, afbeelding 1 van 2 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 4, afbeelding 2 van 2
    • Use both hands to remove the keyboard.
    • Potential for device damage: Do not pull too forcibly or you could damage your keyboard.
  5. Acer Aspire TimelineU M5-481TG Audio Drive Replacement, Battery: stap 5, afbeelding 1 van 1
    • Gently disconnect the silver cable that stretches over the battery by using your fingernail to flip up the small retaining flaps on both sides of the zero insertion force connector.
    • Potential for device damage: Be sure you are prying up the hinged retaining flap, not the connector itself.
  6. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove one 3 mm screw from the side closest to you on the motherboard with a JIS #1 screwdriver.
    • Remove one 4 mm screw from the right side of the motherboard with a JIS #1 screwdriver.
  7. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 7, afbeelding 1 van 2 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 7, afbeelding 2 van 2
    • Use your fingernail to flip up the small retaining flap of the zero insertion force connector and then gently pull out the silver ribbon cable.
  8. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 8, afbeelding 1 van 2 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 8, afbeelding 2 van 2
    • Gently disconnect the six bundled cables (red, black, and green) attached to both the battery and motherboard by pinching them with your thumb and forefinger. Pull with moderate force towards the left to disconnect.
  9. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 9, afbeelding 1 van 3 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 9, afbeelding 2 van 3 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 9, afbeelding 3 van 3
    • Gently lift up the black-covered cables that remain connected to the motherboard at the bottom left of the laptop base.
    • Move the cables toward the bottom edge of the laptop closest to you without disconnecting them.
    • Potential for device damage: Do not pull too forcibly or you could damage your motherboard.
    • Carefully lift up the motherboard and slide the battery to the left to pull it out.
  10. Acer Aspire TimelineU M5-481TG Audio Drive Replacement, Motherboard: stap 10, afbeelding 1 van 2 Acer Aspire TimelineU M5-481TG Audio Drive Replacement, Motherboard: stap 10, afbeelding 2 van 2
    • Use your fingernail to flip up the small retaining flap of zero insertion force connector and then gently out pull the silver ribbon cable.
  11. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 11, afbeelding 1 van 3 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 11, afbeelding 2 van 3 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 11, afbeelding 3 van 3
    • Gently use your fingernail to push the white ribbon cable away from its connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
  12. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 12, afbeelding 1 van 3 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 12, afbeelding 2 van 3 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 12, afbeelding 3 van 3
  13. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 13, afbeelding 1 van 2 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 13, afbeelding 2 van 2
    • Gently lift up the motherboard with your hands to remove it.
  14. Acer Aspire TimelineU M5-481TG Audio Drive Replacement, Audio Drive: stap 14, afbeelding 1 van 2 Acer Aspire TimelineU M5-481TG Audio Drive Replacement, Audio Drive: stap 14, afbeelding 2 van 2
    • Use the #J1 Phillips Head screwdriver to unscrew three 4 mm #J1 screws from the side of the motherboard closest to you.
    • Pick up the audio drive from bottom left corner of computer.
  15. Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 15, afbeelding 1 van 3 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 15, afbeelding 2 van 3 Acer Aspire TimelineU M5-481TG Audio Drive Replacement: stap 15, afbeelding 3 van 3
    • Lift motherboard and gently pull audio drive wire towards you until the wire is free.
    • Lift speaker at bottom right of computer to remove the audio drive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Margaret Bruetsch
387 Reputatie
2 handleidingen geschreven
Marist, Team 1-2, Laflen Spring 2016 Lid van Marist, Team 1-2, Laflen Spring 2016
MARS-LAFLEN-S16S1G2
3 Leden
6 handleidingen geschreven
Één opmerking
Hi I have acer aspire m5 481tg before 2 weeks its shut down and no more working ,I replaced motherboard ram but still not working please help me ,if any one can help me contact me starlov@gmail.com
Ali - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 709
