Ga door naar hoofdinhoud
Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement
Wat je nodig hebt
  1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: stap 1, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: stap 1, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: stap 1, afbeelding 3 van 3
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover using the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 2, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 2, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 2, afbeelding 3 van 3
    • Remove the yellow tape from the board cables.
    • Carefully unplug the two board cables from their connectors by pulling on them.
  3. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 3, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 3, afbeelding 2 van 2
    • Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place.
  4. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 4, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 4, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 4, afbeelding 3 van 3
    • Lift up the metal tab on the left side using the opening tool.
    • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  5. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 5, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 5, afbeelding 2 van 2
    • Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place.
  6. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 6, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 6, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 6, afbeelding 3 van 3
    • Lift the metal tab on the right side up using the opening tool.
  7. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 7, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 7, afbeelding 2 van 2
    • Insert the opening tool between the two sections of the device.
    • Lift up the keyboard section using the opening tool.
  8. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 8, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 8, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 8, afbeelding 3 van 3
    • Carefully pull up on the keyboard section using your hands to remove it from the screen section.
  9. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 9, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 9, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: stap 9, afbeelding 3 van 3
    • Pull the docking connector off of the screen section.
Conclusie
Grecia Corrada
1.134 Reputatie
6 handleidingen geschreven
Baylor, Team S3-G3, Williams Spring 2018 Lid van Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 Leden
Één opmerking
Where do you get the docking ports or whatever it is called? With the magnets
Michael - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 2,922
