Ga door naar hoofdinhoud
Acer Aspire Switch 10 SW5-012-18MY Battery Replacement
Wat je nodig hebt
  1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the tablet from the keyboard.
    • You will not be needing the keyboard for this guide.
  2. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 2, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 2, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 2, afbeelding 3 van 3
    • Use the opening tool to open the back cover. The opening tool should fit under the cover if you place it above the power button.
    • Lift this side of the back cover once the opening tool is inside the device.
    • Use the opening tool and your hands to gradually work around the edges of the cover.
  3. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 3, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 3, afbeelding 2 van 2
    • Lift the back cover off of the device with your hands.
    • You will need to use some force to pull off the back cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 4, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the piece of black, thin tape that is attached to the circuit board closest to the power button.
  5. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 5, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 5, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 5, afbeelding 3 van 3
    • Use the opening tool to lift the ZIF connector holding the ribbon cable in place on the circuit board.
    • Pull out the ribbon cable from the circuit board. This cable should have the word "Audio" on it.
  6. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 6, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 6, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 6, afbeelding 3 van 3
    • Remove the piece of thin, black tape that is attached to the circuit board on the other side of the battery.
    • Use the opening tool to lift the black ZIF connector holding the ribbon cable in place.
  7. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 7, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 7, afbeelding 2 van 2
    • Partially remove the piece of black tape that is holding the bundled cable connector to the battery in place.
    • Pull on the battery's bundled cable connector to unplug it from the circuit board.
  8. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 8, afbeelding 1 van 1
    • Using the Phillips #000 screwdriver, remove the 3 mm screw that is holding the battery in place.
  9. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 9, afbeelding 1 van 1
    • Gently remove the ribbon cable from the battery.
  10. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 10, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: stap 10, afbeelding 2 van 2
    • Carefully remove the battery from the device by lifting it up.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Grecia Corrada
1.134 Reputatie
6 handleidingen geschreven
Baylor, Team S3-G3, Williams Spring 2018 Lid van Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 42
Altijd: 4,422
