Ga door naar hoofdinhoud
Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement
Wat je nodig hebt
  1. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement, Touchpad: stap 1, afbeelding 1 van 1
    • Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
    • This screw does not need to be removed because it doesn't hold the backplate in.
  2. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: stap 2, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: stap 2, afbeelding 2 van 2
    • Push the plastic opening tool into the crevice between the front and back panel.
    • Pull down on the plastic opening tool like a lever to create space and slide along the crevice to remove the back panel.
  3. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: stap 3, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: stap 3, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: stap 3, afbeelding 3 van 3
    • Gently slide the plastic opening tool under the black clip that is attached to the ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  4. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: stap 4, afbeelding 1 van 1
    • Remove the touchpad.
Conclusie
Max Francois
684 Reputatie
2 handleidingen geschreven
USF Tampa, Team 3-4, Passmore Fall 2016 Lid van USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Leden
4 handleidingen geschreven
Één opmerking
Thank you for the steps. I want to know if a replacement keyboard is available in the market. I did not find online.
Gibson Castelino - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 1,563
