Ga door naar hoofdinhoud
Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement
Wat je nodig hebt
  1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: stap 1, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: stap 1, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: stap 1, afbeelding 3 van 3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 2, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 2, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 2, afbeelding 3 van 3
    • There is one zero insertion force connector that needs to be removed.
    • Use your plastic opening tool to flip up the black clip that secures the ribbon cable to the motherboard.
    • Once the clip is flipped up, the ribbon cable will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 3, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 3, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 3, afbeelding 3 van 3
    • To remove the four bundled cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  4. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 4, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 4, afbeelding 2 van 2
    • Use a pair of tweezers to gently pull up the speaker closest to the motherboard.
  5. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 5, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 5, afbeelding 2 van 2
    • Remove any tape that may be holding down the speakers or wires in place.
  6. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 6, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 6, afbeelding 2 van 2
    • Use tweezers to gently pull up the second speaker.
  7. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: stap 7, afbeelding 1 van 1
    • Remove and replace the speakers.
Conclusie
Richard Colon
480 Reputatie
2 handleidingen geschreven
USF Tampa, Team 3-4, Passmore Fall 2016 Lid van USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,345
