Ga door naar hoofdinhoud
Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement
Wat je nodig hebt
  1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 2, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 2, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • There are four zero insertion force connectors that need to be removed.
    • Use your plastic opening tool to flip up the black clips that secure the ribbon cables to the motherboard.
    • Once the clips are flipped up, the ribbon cables will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 3, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 3, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Use your plastic opening tool to pry up and lift the antenna cables from the motherboard.
    • The connectors are delicate so use a gentle touch when prying them.
  4. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 4, afbeelding 1 van 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 4, afbeelding 2 van 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • To remove the four bundle cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  5. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 5, afbeelding 1 van 2 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use your screwdriver with the Phillips PH000 attachment to remove the three 4mm screws.
    • Remove the motherboard from the tablet.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Max Francois
684 Reputatie
2 handleidingen geschreven
USF Tampa, Team 3-4, Passmore Fall 2016 Lid van USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 7,357
