Inleiding
In this guide you will learn how to replace the LCD of the Acer Aspire. The screen and LCD are glued together on this device, so should a screen replacement be necessary a LCD replacement will be the required repair. To determine if an LCD replacement is required, please refer to the troubleshooting page for this device.
Wat je nodig hebt
Use a heat gun to heat the edges of the screen, loosening the adhesive underneath.
Run a jimmy or similarly thin object around the edge of the screen.
Using a suction cup, lift up on the screen to separate it from the adhesive.
Één andere persoon heeft deze handleiding voltooid.
