Inleiding
To replace the battery in the Acer Aspire, some common tools will be needed. A T6 Torx screwdriver as well as a Phillips #01 screwdriver will be needed to remove screws on the back panel and to remove the battery itself. To determine if the battery is in need of replacement, please refer to the troubleshooting page for this device.
Wat je nodig hebt
Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
After all marked screws have been removed, lift up back panel to expose internal parts.
Één andere persoon heeft deze handleiding voltooid.
