Ga door naar hoofdinhoud
Acer Aspire S7-392-6484 Battery Replacement
Wat je nodig hebt
  1. Acer Aspire S7-392-6484 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Aspire S7-392-6484 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
    • Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
    • After all marked screws have been removed, lift up back panel to expose internal parts.
  2. Acer Aspire S7-392-6484 Battery Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the marked 1.5 mm screws with a Phillips #01 screwdriver.
  3. Acer Aspire S7-392-6484 Battery Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the cable located at the top of the battery. Be careful to pull the cable horizontally, not vertically.
  4. Acer Aspire S7-392-6484 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicholas Wise
754 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G6, Eyestone Spring 2018 Lid van USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 5,484
