Ga door naar hoofdinhoud
Acer Aspire S7-392 Fan replacement Replacement
Wat je nodig hebt
  1. Acer Aspire S7-392 Fan replacement Replacement, Opening the case: stap 1, afbeelding 1 van 3 Acer Aspire S7-392 Fan replacement Replacement, Opening the case: stap 1, afbeelding 2 van 3 Acer Aspire S7-392 Fan replacement Replacement, Opening the case: stap 1, afbeelding 3 van 3
    • First, remove the 3 long torx t5 screws (red) and the 8 short ones (orange).
    • Once you have removed the screws, you can pry off the bottom panel.
    • Make sure to start by prying up on the bottom of the panel, then work your way around.
  2. Acer Aspire S7-392 Fan replacement Replacement, The fan: stap 2, afbeelding 1 van 2 Acer Aspire S7-392 Fan replacement Replacement, The fan: stap 2, afbeelding 2 van 2
    • Unplug the flex cable at the bottom left of the fan by flipping up the release tab and pulling. Also remove the two Philips #0 screws (red) securing the fan. The fan should then pull out without too much difficulty
    • If you are doing the other fan from me, the process should remain virtually same.
    • Be careful of the black cable over the top of the fan. It should be seated the same way on the new fan.
  3. Acer Aspire S7-392 Fan replacement Replacement, The new fan: stap 3, afbeelding 1 van 2 Acer Aspire S7-392 Fan replacement Replacement, The new fan: stap 3, afbeelding 2 van 2
    • Simply install the new fan in the opposite order that you removed the old one. Put everything back together and boot the computer. The new fan should now be working.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joshua Feist
74 Reputatie
1 Handleiding geschreven
Één opmerking
Very good, but this says nothing about the other fan
Anson Ma - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 2,049
