Ga door naar hoofdinhoud
Acer Aspire S3-951-6432 Motherboard Replacement
Wat je nodig hebt
  1. Acer Aspire S3-951-6432 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 3 Acer Aspire S3-951-6432 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 3 Acer Aspire S3-951-6432 Motherboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Keeping it closed, turn the laptop upside down.
    • With the Phillips #0 screwdriver, remove the twelve 5 mm screws that hold the laptop together.
    • Insert the plastic opening tool between the plastic casings to pull the bottom lid of the laptop up.
    • You do not need to pull the lid all the way off.
  2. Acer Aspire S3-951-6432 Motherboard Replacement: stap 2, afbeelding 1 van 3 Acer Aspire S3-951-6432 Motherboard Replacement: stap 2, afbeelding 2 van 3 Acer Aspire S3-951-6432 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Locate the six cables that are connected to the motherboard. The cable with the white strip is located underneath the cable with the orange strip.
    • Using the plastic opening tool on one side and your fingernail on the other, wedge each cable out of its socket.
    • The battery is now disconnected. If you want to remove the battery, follow the remaining steps in this guide. However, if you only wish to disconnect the battery to do other internal work, skip the remaining steps in this guide and continue on to other guides.
  3. Acer Aspire S3-951-6432 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • With the Phillips #0 screwdriver, remove the two 5 mm screws that are located above the long black piece of the battery.
  4. Acer Aspire S3-951-6432 Motherboard Replacement: stap 4, afbeelding 1 van 3 Acer Aspire S3-951-6432 Motherboard Replacement: stap 4, afbeelding 2 van 3 Acer Aspire S3-951-6432 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Locate the two speakers for this laptop that are connected above the battery by a thin red cord.
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the left speaker in place.
    • Pull the left speaker up along with the red cord and leave it off to the right side.
    • If you plan to disassemble the laptop down to the motherboard, you will also need to remove the two 3 mm screws holding the right-side speaker in place with a Phillips #0 screwdriver.
  5. Acer Aspire S3-951-6432 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Without bending it, lift the entire battery (both the long black piece and the rectangular blue piece) straight up. Place it off to one side.
  6. Acer Aspire S3-951-6432 Motherboard Replacement, Hard Drive (HDD/SDD): stap 6, afbeelding 1 van 2 Acer Aspire S3-951-6432 Motherboard Replacement, Hard Drive (HDD/SDD): stap 6, afbeelding 2 van 2
    • Locate the hard drive, which is the black rectangular object just above the battery.
  7. Acer Aspire S3-951-6432 Motherboard Replacement: stap 7, afbeelding 1 van 2 Acer Aspire S3-951-6432 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Lift the silver and yellow cable next to the hard drive up with the spudger.
  8. Acer Aspire S3-951-6432 Motherboard Replacement: stap 8, afbeelding 1 van 2 Acer Aspire S3-951-6432 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Underneath the yellow cable, there is another gray and black cable.
    • Use your fingernails to pull the gray and black cable out of its connector.
  9. Acer Aspire S3-951-6432 Motherboard Replacement: stap 9, afbeelding 1 van 2 Acer Aspire S3-951-6432 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Pull on the blue tab near the hard drive to remove the connector for the motherboard.
  10. Acer Aspire S3-951-6432 Motherboard Replacement: stap 10, afbeelding 1 van 3 Acer Aspire S3-951-6432 Motherboard Replacement: stap 10, afbeelding 2 van 3 Acer Aspire S3-951-6432 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove the single 3 mm screw from the top of the hard drive sled.
    • Lift the rectangular tab to pull the hard drive out of the laptop .
  11. Acer Aspire S3-951-6432 Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 3 Acer Aspire S3-951-6432 Motherboard Replacement, Motherboard: stap 11, afbeelding 2 van 3 Acer Aspire S3-951-6432 Motherboard Replacement, Motherboard: stap 11, afbeelding 3 van 3
    • Disconnect the eight cables that connect directly to the motherboard.
    • There are two connector styles: Standard Connectors (which have two pieces that stick out and make them easier to remove - see the second image for an example), and Alligator Clips (which have a plastic piece that folds up and allows the cable to be removed - see the third image for an example). Both kinds connect to the motherboard.
  12. Acer Aspire S3-951-6432 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the single 3 mm screw holding the motherboard in place.
    • Using the sides of the motherboard, lift the motherboard out of the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cynthia Bennett
584 Reputatie
5 handleidingen geschreven
UW Tacoma, Team S1-G1, Rose Fall 2018 Lid van UW Tacoma, Team S1-G1, Rose Fall 2018
UWT-ROSE-F18S1G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 1,116
