Ga door naar hoofdinhoud
Acer Aspire S3-391-6046 Battery Replacement
Wat je nodig hebt
  1. Acer Aspire S3-391-6046 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Battery Replacement: stap 2, afbeelding 1 van 2 Acer Aspire S3-391-6046 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Battery Replacement: stap 3, afbeelding 1 van 1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • With the Phillips #1 screwdriver, remove the two 5mm screws located on either side of the battery.
  5. Acer Aspire S3-391-6046 Battery Replacement: stap 5, afbeelding 1 van 2 Acer Aspire S3-391-6046 Battery Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Unplug the three white plugs from their sockets using tweezers by pinching the plugs and pulling them outwards.
    • Pulling with too much force will damage the plugs.
  6. Acer Aspire S3-391-6046 Battery Replacement: stap 6, afbeelding 1 van 2 Acer Aspire S3-391-6046 Battery Replacement: stap 6, afbeelding 2 van 2
    • Pull upwards on the plugs located on top of your battery until they have completely come off.
  7. Acer Aspire S3-391-6046 Battery Replacement: stap 7, afbeelding 1 van 2 Acer Aspire S3-391-6046 Battery Replacement: stap 7, afbeelding 2 van 2
    • Remove the electrical tape holding down the battery by peeling it upwards.
    • Grab the battery from the bottom and slide it out towards the direction of the bottom of the battery.
Conclusie
Brian Rodriguez
530 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 734
